<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</guid>
										<title>1986 - 1988 Corvette:  Service Bulletin:  New Heater and Air Condition Control Head Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-new-heater-and-air-condition-control-head-assembly-1028.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: Engine Noise - Install Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-zr-1-service-bulletin-lack-of-wide-open-throttle-engine-underpower-479.html</guid>
										<title>1992 Corvette ZR-1: Service Bulletin: Lack of Wide Open Throttle Engine Underpower</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-zr-1-service-bulletin-lack-of-wide-open-throttle-engine-underpower-479.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</guid>
										<title>1988 - 1992 Corvette: Service Bulletin: A/C Compressor Sealing Washer (New Design)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1992-corvette-service-bulletin-a-c-compressor-sealing-washer-new-design-724.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Body Emblem Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</guid>
										<title>1990 Corvette: Service Bulletin: L98 and LT5: Revised Air Conditioning Control Circuit Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-l98-and-lt5-revised-air-conditioning-control-circuit-diagnosis-722.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-campaign-fuel-lines-may-crack-fuel-leak-481.html</guid>
										<title>1990 Corvette ZR-1: Campaign: Fuel Lines May Crack / Fuel Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-campaign-fuel-lines-may-crack-fuel-leak-481.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Diagnosing Low Tire Pressure Warning System Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-diagnosing-low-tire-pressure-warning-system-codes-5.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</guid>
										<title>1990 Corvette: Service Bulletin: Loss of Heating or Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
