<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-front-park-turn-signal-bulb-intermittently-inoperative-205.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Front Park/Turn Signal Bulb Intermittently Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-front-park-turn-signal-bulb-intermittently-inoperative-205.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</guid>
										<title>2006 Corvette: Electrical Schematic: Instrument and Interior Lights</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-cooling-fans-209.html</guid>
										<title>2006 Corvette: Electrical Schematic: Cooling Fans</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-cooling-fans-209.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-camapaign-service-active-handling-92.html</guid>
										<title>2005 - 2006 Corvette: Camapaign: Service Active Handling</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-camapaign-service-active-handling-92.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</guid>
										<title>2005 - 2019 Corvette: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2010-corvette-service-bulletin-pic5346a-normal-characteristic-unable-to-answer-a-second-incoming-bluetooth-call-or-continues-to-ring-after-answering-a-second-incoming-call-1329.html</guid>
										<title>2009 - 2010 Corvette: Service Bulletin: #PIC5346A: Normal Characteristic - Unable To Answer a Second Incoming Bluetooth call or Continues To Ring After Answering a Second Incoming Call</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-special-coverage-adjustment-airbag-light-on-1264.html</guid>
										<title>2005 - 2013 Corvette: Service Bulletin: Special Coverage Adjustment - Airbag Light On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-special-coverage-adjustment-airbag-light-on-1264.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-safety-recall-number-13149-low-beam-headlamps-inoperative-1097.html</guid>
										<title>2005 - 2007 Corvette:  Safety Recall:  Number 13149, Low-Beam Headlamps Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-safety-recall-number-13149-low-beam-headlamps-inoperative-1097.html</link>
