<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-corvette-body-repair-materials-659.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</guid>
										<title>1988 - 1989 Corvette:  Hood Rubs Air Conditioning Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</guid>
										<title>1990 Corvette: Service Bulletin: Competition Yellow Paint Comments About Color Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-1984-corvettes-painted-with-1986-colors-for-general-managers-color-show-76.html</guid>
										<title>1984 - 1986 Corvette:  Service Bulletin:  1984 Corvettes Painted with 1986 Colors for General Managers Color Show</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-1984-corvettes-painted-with-1986-colors-for-general-managers-color-show-76.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-windshield-wipers-chatter-and-or-wipe-unevenly-1089.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Windshield Wipers Chatter and/or Wipe Unevenly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-windshield-wipers-chatter-and-or-wipe-unevenly-1089.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-paint-etching-staining-and-permanent-water-spotting-662.html</guid>
										<title>1985 - 1991 Corvette: Service Bulletin: Paint Etching/Staining and Permanent Water Spotting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-paint-etching-staining-and-permanent-water-spotting-662.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</guid>
										<title>1994 - 1995 Corvette:  Service Bulletin:  Door Glass Scratching (Replace outer seal in addition to glass)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1993-corvette-service-bulletin-rear-lift-window-hard-to-open-hinge-loose-to-glass-669.html</guid>
										<title>1984 - 1993 Corvette: Service Bulletin: Rear Lift Window Hard to Open/Hinge Loose to Glass</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1993-corvette-service-bulletin-rear-lift-window-hard-to-open-hinge-loose-to-glass-669.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</guid>
										<title>1984 - 1996 Corvette: Water Leakage: Preventing Water Leaks Into the Interior Near Side Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Cracks/Damage to Cowl Surface</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Cleaning and Lubricating Power Antenna Mast Sections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
