<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-information-on-door-lock-system-components-and-replacement-components-653.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</guid>
										<title>1994 - 1995 Corvette:  Service Bulletin:  Door Glass Scratching (Replace outer seal in addition to glass)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-hood-will-not-open-cable-disconnection-648.html</guid>
										<title>1993 Corvette: Service Bulletin: Hood Will Not Open - Cable Disconnection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-hood-will-not-open-cable-disconnection-648.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Cleaning and Lubricating Power Antenna Mast Sections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-window-assist-rods-664.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Rear Hatch Window Assist Rods</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-window-assist-rods-664.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-pace-car-decal-installation-74.html</guid>
										<title>1986 Corvette:  Pace Car Decal Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-pace-car-decal-installation-74.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-paint-repair-without-repainting-996.html</guid>
										<title>1984 - 1985 Corvette:  Service Bulletin:  Paint Repair Without Repainting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-paint-repair-without-repainting-996.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-corvette-body-repair-materials-659.html</guid>
										<title>1986 Corvette: Service Bulletin: Corvette Body Repair Materials</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-corvette-body-repair-materials-659.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-protective-transit-coating-for-exterior-paint-651.html</guid>
										<title>1991 Corvette: Service Bulletin: Protective Transit Coating for Exterior Paint</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-protective-transit-coating-for-exterior-paint-651.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</guid>
										<title>1984 - 1996 Corvette: Water Leakage: Preventing Water Leaks Into the Interior Near Side Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</guid>
										<title>1988 - 1989 Corvette:  Hood Rubs Air Conditioning Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-hood-rubs-air-conditioning-hose-1102.html</link>
