<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-protective-transit-coating-for-exterior-paint-651.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-right-door-glass-binds-insufficient-travel-unable-to-contact-weatherstrips-647.html</guid>
										<title>1993 Corvette: Service Bulletin: Right Door Glass Binds, Insufficient Travel, Unable to Contact Weatherstrips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-right-door-glass-binds-insufficient-travel-unable-to-contact-weatherstrips-647.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-corvette-body-repair-materials-659.html</guid>
										<title>1986 Corvette: Service Bulletin: Corvette Body Repair Materials</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-corvette-body-repair-materials-659.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</guid>
										<title>1991 Corvette: Service Bulletin: Squeak and Rattle Diagnosis Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Cleaning and Lubricating Power Antenna Mast Sections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-window-assist-rods-664.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Rear Hatch Window Assist Rods</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-window-assist-rods-664.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Roof Panel Attaching Point Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-technical-instructions-headlight-motor-gear-replacement-1222.html</guid>
										<title>1988 - 1996 Corvette:  Technical Instructions:  Headlight Motor Gear Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-technical-instructions-headlight-motor-gear-replacement-1222.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</guid>
										<title>1990 Corvette: Service Bulletin: Competition Yellow Paint Comments About Color Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-front-center-air-deflector-damage-1217.html</guid>
										<title>1984 - 1987 Corvette:  Service Bulletin:  Front Center Air Deflector Damage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-front-center-air-deflector-damage-1217.html</link>
