<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2010-corvette-gm-techlink-corvette-battery-charger-accessory-65.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Horn System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</guid>
										<title>2006 Corvette: Electrical Schematic: Instrument and Interior Lights</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-instrument-and-interior-lights-198.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-automatic-ac-system-210.html</guid>
										<title>2006 Corvette: Electrical Schematic: Automatic AC System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-automatic-ac-system-210.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-language-change-for-onstar-system-u-s-only-197.html</guid>
										<title>2006 Corvette: Service Bulletin: Language Change for OnStar System (U.S. Only)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-language-change-for-onstar-system-u-s-only-197.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-wipers-will-not-park-131.html</guid>
										<title>2005 - 2006 Corvette:  Service Bulletin:  Wipers Will Not Park</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-wipers-will-not-park-131.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-347.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</guid>
										<title>2005 (Canadian Corvettes Only): Recall 04096: Incorrect Air Bag Off Indicator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-1332.html</guid>
										<title>2005 - 2013 Corvette: Service Bulletin: #PIC5049A: Fuel Tank Hard to Fill Or Displays 1/2 Tank After Filling - (Oct 22, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-1332.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-1337.html</guid>
										<title>2007 - 2013 Corvette: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-2013-corvette-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-1337.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-front-park-turn-signal-bulb-intermittently-inoperative-205.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Front Park/Turn Signal Bulb Intermittently Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-front-park-turn-signal-bulb-intermittently-inoperative-205.html</link>
