<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-brake-pad-replacement-part-numbers-645.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</guid>
										<title>1986 - 1991 Corvette: Service Bulletin: Information on ABS Noise - Self Test</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-recall-notice-product-campaign-90c09-inoperative-parking-brake-1095.html</guid>
										<title>1989 - 1990 Corvette:  Recall Notice:  Product Campaign 90C09 Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-recall-notice-product-campaign-90c09-inoperative-parking-brake-1095.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: How to Replace Your Front Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</guid>
										<title>1984 Corvette: Recall: Front Brake Caliper Bracket Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-change-in-brake-effectiveness-after-brake-work-632.html</guid>
										<title>1984 - 1996 Corvette: Service Bulletin: Change in Brake Effectiveness After Brake Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-change-in-brake-effectiveness-after-brake-work-632.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-brake-pedal-not-fully-returning-stop-lights-stay-on-and-or-roughness-vibration-from-rear-of-vehicle-634.html</guid>
										<title>1992 Corvette: Service Bulletin: Brake Pedal Not Fully Returning / Stop Lights Stay On and/or Roughness/Vibration From Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-brake-pedal-not-fully-returning-stop-lights-stay-on-and-or-roughness-vibration-from-rear-of-vehicle-634.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</guid>
										<title>1988 -1996 Corvette : Visual Differences Between Production Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Brake Service Light/ABS Light Comes On (False Code 83)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-squeal-642.html</guid>
										<title>1984 Corvette: Service Bulletin: Brake Squeal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-squeal-642.html</link>
