<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-pad-hold-down-spring-breakage-643.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-change-in-brake-effectiveness-after-brake-work-632.html</guid>
										<title>1984 - 1996 Corvette: Service Bulletin: Change in Brake Effectiveness After Brake Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-change-in-brake-effectiveness-after-brake-work-632.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</guid>
										<title>1986 - 1991 Corvette: Service Bulletin: Information on ABS Noise - Self Test</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</guid>
										<title>1984 Corvette: Recall: Front Brake Caliper Bracket Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-brake-pedal-not-fully-returning-stop-lights-stay-on-and-or-roughness-vibration-from-rear-of-vehicle-634.html</guid>
										<title>1992 Corvette: Service Bulletin: Brake Pedal Not Fully Returning / Stop Lights Stay On and/or Roughness/Vibration From Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-brake-pedal-not-fully-returning-stop-lights-stay-on-and-or-roughness-vibration-from-rear-of-vehicle-634.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: How to Replace Your Front Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</guid>
										<title>1995 - 2002 Corvette: Service Bulletin: Warranty Admin. - Brake Rotor Warranty Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</guid>
										<title>1986 Corvette:  Recall Notice:  Anti-Skid Brake System Master Cylinder Center Valve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</guid>
										<title>1990 Corvette: Recall: Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Brake Service Light/ABS Light Comes On (False Code 83)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</link>
