<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-abs-pump-noisy-abs-active-light-flashes-637.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Brake Service Light/ABS Light Comes On (False Code 83)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-recall-notice-product-campaign-90c09-inoperative-parking-brake-1095.html</guid>
										<title>1989 - 1990 Corvette:  Recall Notice:  Product Campaign 90C09 Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-recall-notice-product-campaign-90c09-inoperative-parking-brake-1095.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</guid>
										<title>1986 Corvette:  Recall Notice:  Anti-Skid Brake System Master Cylinder Center Valve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</guid>
										<title>1986 - 1991 Corvette: Service Bulletin: Information on ABS Noise - Self Test</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</guid>
										<title>1995 - 2002 Corvette: Service Bulletin: Warranty Admin. - Brake Rotor Warranty Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-2002-corvette-service-bulletin-warranty-admin-brake-rotor-warranty-service-procedure-452.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-brake-pad-replacement-part-numbers-645.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Brake Pad Replacement Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-brake-pad-replacement-part-numbers-645.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</guid>
										<title>1984 Corvette: Recall: Front Brake Caliper Bracket Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-squeal-642.html</guid>
										<title>1984 Corvette: Service Bulletin: Brake Squeal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-squeal-642.html</link>
