<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-rear-axle-differential-cross-shaft-retention-628.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1994-corvette-service-bulletin-reduced-power-steering-assist-at-low-ambient-temperatures-618.html</guid>
										<title>1991 - 1994 Corvette: Service Bulletin: Reduced Power Steering Assist at Low Ambient Temperatures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1994-corvette-service-bulletin-reduced-power-steering-assist-at-low-ambient-temperatures-618.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-front-suspension-revised-torque-specifications-619.html</guid>
										<title>1990 Corvette: Service Manual Update: Front Suspension Revised Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-front-suspension-revised-torque-specifications-619.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-notice-rear-wheel-tie-rod-1167.html</guid>
										<title>1988 - 1989 Corvette:  Recall Notice:  Rear Wheel Tie Rod</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-notice-rear-wheel-tie-rod-1167.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</guid>
										<title>1990 Corvette: Service Bulletin: Clicking Noise When Steering Wheel is Rotated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-rebuilding-bilstein-shocks-by-bilstein-corporation-621.html</guid>
										<title>1989 - 1995 Corvette: Rebuilding Bilstein Shocks by Bilstein Corporation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-rebuilding-bilstein-shocks-by-bilstein-corporation-621.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-tech-article-the-inside-story-of-c4-s-shock-absorber-revolution-selective-ride-control-139.html</guid>
										<title>1989 - 1995 Corvette: Tech Article:  The Inside Story of C4`s Shock Absorber Revolution, Selective Ride Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-tech-article-the-inside-story-of-c4-s-shock-absorber-revolution-selective-ride-control-139.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</guid>
										<title>1994 - 1996 Corvette: Service Bulletin: Intermittent Steering Column Snap or Clink Noise When Turn</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-ride-harshness-z51-suspension-626.html</guid>
										<title>1984 Corvette: Service Bulletin: Ride Harshness - Z51 Suspension</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-ride-harshness-z51-suspension-626.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-recall-power-steering-gear-inlet-hose-617.html</guid>
										<title>1992 - 1993 Corvette: Recall: Power Steering Gear Inlet Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-recall-power-steering-gear-inlet-hose-617.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</guid>
										<title>1984 Corvette: Service Bulletin: Rack / Pinion Power Steering Valve Ring Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</link>
