<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html</guid>
										<title>1990 Corvette: Recall: Product Campaign 90C07 Instrument Panel Wire Abrasion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</guid>
										<title>1990 - 1995 Corvette | ZR-1: AC Compressor Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-hard-start-on-hot-restart-increased-idle-speed-484.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Hard Start on Hot Restart / Increased Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-hard-start-on-hot-restart-increased-idle-speed-484.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</guid>
										<title>1984 Corvette: Service Bulletin: Rack / Pinion Power Steering Valve Ring Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-engine-exchange-program-1018.html</guid>
										<title>1990 Corvette ZR-1:  Service Bulletin:  Engine Exchange Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-engine-exchange-program-1018.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-zr-1-service-bulletin-lack-of-wide-open-throttle-engine-underpower-479.html</guid>
										<title>1992 Corvette ZR-1: Service Bulletin: Lack of Wide Open Throttle Engine Underpower</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-zr-1-service-bulletin-lack-of-wide-open-throttle-engine-underpower-479.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-notice-rear-wheel-tie-rod-1167.html</guid>
										<title>1988 - 1989 Corvette:  Recall Notice:  Rear Wheel Tie Rod</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-notice-rear-wheel-tie-rod-1167.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</guid>
										<title>1990 Corvette: Service Bulletin: Clicking Noise When Steering Wheel is Rotated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Body Emblem Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-body-emblem-part-numbers-489.html</link>
