<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-front-suspension-revised-torque-specifications-619.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-rear-axle-differential-cross-shaft-retention-628.html</guid>
										<title>1984 Corvette: Recall: Rear Axle Differential Cross Shaft Retention</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-rear-axle-differential-cross-shaft-retention-628.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-recall-power-steering-gear-inlet-hose-617.html</guid>
										<title>1992 - 1993 Corvette: Recall: Power Steering Gear Inlet Hose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-recall-power-steering-gear-inlet-hose-617.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</guid>
										<title>1988 - 1990 Corvette: Service Bulletin: Power Steering Shudder / Groan</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1990-corvette-service-bulletin-power-steering-shudder-groan-624.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-shocks-oil-film-on-bilstein-shocks-613.html</guid>
										<title>1984 - 1996 Corvette: Shocks: Oil Film on Bilstein Shocks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-shocks-oil-film-on-bilstein-shocks-613.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: Poly Performance: Putting Polyurethane Bushings on Your Late Model Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-news-revised-differential-case-cross-pin-installation-procedure-948.html</guid>
										<title>1985 Corvette:  Service News:  Revised Differential Case Cross Pin Installation Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-news-revised-differential-case-cross-pin-installation-procedure-948.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</guid>
										<title>1994 - 1996 Corvette: Service Bulletin: Intermittent Steering Column Snap or Clink Noise When Turn</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-gm-techlink-rear-spindle-support-rod-protector-sleeve-625.html</guid>
										<title>1984 Corvette: GM TechLink: Rear Spindle Support Rod Protector Sleeve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-gm-techlink-rear-spindle-support-rod-protector-sleeve-625.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-steering-column-popping-noise-616.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Steering Column Popping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-steering-column-popping-noise-616.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-rebuilding-bilstein-shocks-by-bilstein-corporation-621.html</guid>
										<title>1989 - 1995 Corvette: Rebuilding Bilstein Shocks by Bilstein Corporation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-rebuilding-bilstein-shocks-by-bilstein-corporation-621.html</link>
