<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-recall-power-steering-gear-inlet-hose-617.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</guid>
										<title>1990 Corvette: Service Bulletin: Clicking Noise When Steering Wheel is Rotated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: Poly Performance: Putting Polyurethane Bushings on Your Late Model Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-news-revised-differential-case-cross-pin-installation-procedure-948.html</guid>
										<title>1985 Corvette:  Service News:  Revised Differential Case Cross Pin Installation Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-news-revised-differential-case-cross-pin-installation-procedure-948.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</guid>
										<title>1984 Corvette: Service Bulletin: Rack / Pinion Power Steering Valve Ring Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-tech-article-the-inside-story-of-c4-s-shock-absorber-revolution-selective-ride-control-139.html</guid>
										<title>1989 - 1995 Corvette: Tech Article:  The Inside Story of C4`s Shock Absorber Revolution, Selective Ride Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-tech-article-the-inside-story-of-c4-s-shock-absorber-revolution-selective-ride-control-139.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1994-corvette-service-bulletin-reduced-power-steering-assist-at-low-ambient-temperatures-618.html</guid>
										<title>1991 - 1994 Corvette: Service Bulletin: Reduced Power Steering Assist at Low Ambient Temperatures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1994-corvette-service-bulletin-reduced-power-steering-assist-at-low-ambient-temperatures-618.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-gm-techlink-rear-spindle-support-rod-protector-sleeve-625.html</guid>
										<title>1984 Corvette: GM TechLink: Rear Spindle Support Rod Protector Sleeve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-gm-techlink-rear-spindle-support-rod-protector-sleeve-625.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-notice-rear-wheel-tie-rod-1167.html</guid>
										<title>1988 - 1989 Corvette:  Recall Notice:  Rear Wheel Tie Rod</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-notice-rear-wheel-tie-rod-1167.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-revised-horizontal-and-vertical-uniframe-alignment-dimensions-799.html</guid>
										<title>1984 Corvette: Service News: Revised Horizontal and Vertical Uniframe Alignment Dimensions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-revised-horizontal-and-vertical-uniframe-alignment-dimensions-799.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-recall-rear-wheel-shaft-u-joint-retainer-bolts-615.html</guid>
										<title>1993 Corvette: Recall: Rear Wheel Shaft U-Joint Retainer Bolts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-recall-rear-wheel-shaft-u-joint-retainer-bolts-615.html</link>
