<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-steering-column-popping-noise-616.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</guid>
										<title>1994 - 1996 Corvette: Service Bulletin: Intermittent Steering Column Snap or Clink Noise When Turn</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-intermittent-steering-column-snap-or-clink-noise-when-turn-614.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-suspension-chart-629.html</guid>
										<title>1984 - 1996 Corvette: Suspension Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-suspension-chart-629.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-front-suspension-revised-torque-specifications-619.html</guid>
										<title>1990 Corvette: Service Manual Update: Front Suspension Revised Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-front-suspension-revised-torque-specifications-619.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</guid>
										<title>1990 Corvette: Service Bulletin: Clicking Noise When Steering Wheel is Rotated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clicking-noise-when-steering-wheel-is-rotated-620.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-shocks-oil-film-on-bilstein-shocks-613.html</guid>
										<title>1984 - 1996 Corvette: Shocks: Oil Film on Bilstein Shocks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-shocks-oil-film-on-bilstein-shocks-613.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-tech-article-the-inside-story-of-c4-s-shock-absorber-revolution-selective-ride-control-139.html</guid>
										<title>1989 - 1995 Corvette: Tech Article:  The Inside Story of C4`s Shock Absorber Revolution, Selective Ride Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-tech-article-the-inside-story-of-c4-s-shock-absorber-revolution-selective-ride-control-139.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: Poly Performance: Putting Polyurethane Bushings on Your Late Model Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-poly-performance-putting-polyurethane-bushings-on-your-late-model-corvette-631.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-recall-rear-wheel-shaft-u-joint-retainer-bolts-615.html</guid>
										<title>1993 Corvette: Recall: Rear Wheel Shaft U-Joint Retainer Bolts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-recall-rear-wheel-shaft-u-joint-retainer-bolts-615.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-rebuilding-bilstein-shocks-by-bilstein-corporation-621.html</guid>
										<title>1989 - 1995 Corvette: Rebuilding Bilstein Shocks by Bilstein Corporation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1995-corvette-rebuilding-bilstein-shocks-by-bilstein-corporation-621.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-service-manual-update-front-leaf-spring-compressor-adapter-623.html</guid>
										<title>1988 Corvette: Service Bulletin: Service Manual Update Front Leaf Spring Compressor Adapter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-service-manual-update-front-leaf-spring-compressor-adapter-623.html</link>
