<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</guid>
										<title>1984 - 1985 Corvette:  Service Bulletin:  Noise in Direct Drive 4-Speed Manual Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</guid>
										<title>1986 - 1987 Corvette:  Service Bulletin:  Clutch Master Cylinder Push Rod Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</guid>
										<title>1988 - 1993 Corvette: Service Bulletin: Click/Whine in 3rd/4th Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1993-corvette-service-bulletin-click-whine-in-3rd-4th-gear-606.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</guid>
										<title>1996 Corvette: Service Bulletin: 3 - 2 Part Throttle Downshift Flare</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</guid>
										<title>1982 - 1993 Corvette: Service Bulletin: Buzzing Noise at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clutch-apply-plate-material-changed-to-powdered-metal-598.html</guid>
										<title>1990 Corvette: Service Bulletin: Clutch Apply Plate Material Changed to Powdered Metal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clutch-apply-plate-material-changed-to-powdered-metal-598.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-4l60-low-reverse-clutch-new-plate-available-607.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: 4L60 Low &amp; Reverse Clutch New Plate Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-4l60-low-reverse-clutch-new-plate-available-607.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-howling-or-squealing-sound-coming-from-clutch-601.html</guid>
										<title>1989 - 1990 Corvette: Howling, or Squealing Sound Coming From Clutch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-howling-or-squealing-sound-coming-from-clutch-601.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
