<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-howling-or-squealing-sound-coming-from-clutch-601.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-service-program-483.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: Engine Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-service-program-483.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</guid>
										<title>1996 Corvette: Transmission Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-new-low-and-reverse-clutch-support-selective-plate-dimensions-599.html</guid>
										<title>1990 Corvette: Service Bulletin: New Low and Reverse Clutch Support Selective Plate Dimensions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-new-low-and-reverse-clutch-support-selective-plate-dimensions-599.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: New 3-4 Club Plates for 4L60 Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</guid>
										<title>1990 Corvette ZR-1: Service Bulletin: Leaking Radiator Hose Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</guid>
										<title>1990 Corvette: Service Bulletin: Loss of Heating or Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</guid>
										<title>1991 Corvette: Service Bulletin: Loss of Heat/Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-loss-of-heat-cooling-control-672.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</guid>
										<title>1984 - 1989 Corvette:  Service Bulletin: Steering Gear Intermediate Shaft Torque Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-steering-gear-intermediate-shaft-torque-specifications-52.html</link>
