<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-3-2-coast-down-clunk-600.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</guid>
										<title>1984 - 1992 Corvette: Service Bulletin: Intermittent Transmission Downshift / Slip Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-howling-or-squealing-sound-coming-from-clutch-601.html</guid>
										<title>1989 - 1990 Corvette: Howling, or Squealing Sound Coming From Clutch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-howling-or-squealing-sound-coming-from-clutch-601.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</guid>
										<title>1995 - 1996 Corvette: Service Bulletin: Delayed Engagement (Replace Pump Cover Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</guid>
										<title>1996 Corvette: Transmission Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</guid>
										<title>1989 - 1991 Corvette: Service Bulletin: No/Delayed Reverse When Cold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</link>
