<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-campaign-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-60.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</guid>
										<title>2004 Corvette: GM TechLink: Oil Pump to Case Seal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-corvette-gm-techlink-oil-pump-to-case-seal-431.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Needle Bearings Found In Oil Pan (Replace Rocker Arms)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-needle-bearings-found-in-oil-pan-replace-rocker-arms-395.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: SMU - Revised Side Cover and Gasket Replacement (RH)/Differential Carrier Cover and Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-smu-revised-side-cover-and-gasket-replacement-rh-differential-carrier-cover-and-seal-replacement-398.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</guid>
										<title>2001 - 2003 Corvette: Service Bulletin: Engine Knock or Lifter Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-bulletin-engine-knock-or-lifter-noise-393.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</guid>
										<title>1998 - 2002 Corvette: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2002-corvette-service-bulletin-audible-spark-knock-detonation-mil-illuminated-dtc-p0332-set-396.html</link>
