<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clutch-apply-plate-material-changed-to-powdered-metal-598.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-harsh-1-2-upshift-597.html</guid>
										<title>1992 Corvette: Service Bulletin: Harsh 1-2 Upshift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-harsh-1-2-upshift-597.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</guid>
										<title>1984 - 1992 Corvette: Service Bulletin: Intermittent Transmission Downshift / Slip Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</guid>
										<title>1986 - 1987 Corvette:  Service Bulletin:  Clutch Master Cylinder Push Rod Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</guid>
										<title>1982 - 1993 Corvette: Service Bulletin: Buzzing Noise at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: New 3-4 Club Plates for 4L60 Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</guid>
										<title>1995 - 1996 Corvette: Service Bulletin: Delayed Engagement (Replace Pump Cover Assembly)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-delayed-engagement-replace-pump-cover-assembly-594.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</guid>
										<title>1994 Corvette: Service Bulletin: Garage Shift Delay Engagement (New Garage Shift Package)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
