<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-harsh-1-2-upshift-597.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</guid>
										<title>1986 - 1987 Corvette:  Service Bulletin:  Clutch Master Cylinder Push Rod Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-clutch-master-cylinder-push-rod-bushing-904.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</guid>
										<title>1989 - 1991 Corvette: Service Bulletin: No/Delayed Reverse When Cold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</guid>
										<title>1995 Corvette: Service Bulletin: 3 - 2 Downshift Flare (Reflash Control Module)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-transmission-whine-noise-loss-of-motion-in-all-gears-or-missing-clutch-disc-rivets-596.html</guid>
										<title>1993 Corvette: Service Bulletin: Transmission &quot;Whine&quot; Noise, Loss of Motion in all Gears, or Missing Clutch Disc Rivets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-transmission-whine-noise-loss-of-motion-in-all-gears-or-missing-clutch-disc-rivets-596.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clutch-apply-plate-material-changed-to-powdered-metal-598.html</guid>
										<title>1990 Corvette: Service Bulletin: Clutch Apply Plate Material Changed to Powdered Metal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-clutch-apply-plate-material-changed-to-powdered-metal-598.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</guid>
										<title>1995 - 1996  Corvette: Service Bulletin: Transmission Fluid Leak From Pump Body</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-1996-corvette-service-bulletin-transmission-fluid-leak-from-pump-body-593.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: New 3-4 Club Plates for 4L60 Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</link>
