										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</guid>
										<title>1990 - 1995 Corvette | ZR-1: AC Compressor Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-ac-compressor-specifications-491.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-transmission-whine-noise-loss-of-motion-in-all-gears-or-missing-clutch-disc-rivets-596.html</guid>
										<title>1993 Corvette: Service Bulletin: Transmission &quot;Whine&quot; Noise, Loss of Motion in all Gears, or Missing Clutch Disc Rivets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-transmission-whine-noise-loss-of-motion-in-all-gears-or-missing-clutch-disc-rivets-596.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-campaign-fuel-lines-may-crack-fuel-leak-481.html</guid>
										<title>1990 Corvette ZR-1: Campaign: Fuel Lines May Crack / Fuel Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-campaign-fuel-lines-may-crack-fuel-leak-481.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-engine-exchange-program-1018.html</guid>
										<title>1990 Corvette ZR-1:  Service Bulletin:  Engine Exchange Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-engine-exchange-program-1018.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</guid>
										<title>1990 Corvette: Service Bulletin: Loss of Heating or Cooling Control</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-loss-of-heating-or-cooling-control-673.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</guid>
										<title>1990 Corvette: Recall: Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</guid>
										<title>1992 - 1996 Corvette: Tech Article: Quietly Powerful: How to Build a C4 LT1/4/5 Exhaust that Gains 28 hp and...is Quiet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</link>
