<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: New 3-4 Club Plates for 4L60 Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-new-3-4-club-plates-for-4l60-transmissions-608.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</guid>
										<title>Regarding Product Campaign Bulletin 95-C-16 High Shift Effort into Reverse Gear on Manual Transmission - 1995 Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</guid>
										<title>1984 - 1992 Corvette: Service Bulletin: Intermittent Transmission Downshift / Slip Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1992-corvette-service-bulletin-intermittent-transmission-downshift-slip-diagnosis-612.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</guid>
										<title>1996 Corvette: Service Bulletin: 3 - 2 Part Throttle Downshift Flare</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-differences-between-first-and-second-generation-zf-6-speed-transmissions-605.html</guid>
										<title>1989 - 1996 Corvette: Differences between First and Second Generation ZF 6-Speed Transmissions</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</guid>
										<title>1984 - 1985 Corvette:  Service Bulletin:  Noise in Direct Drive 4-Speed Manual Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
