<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-service-bulletin-3-2-part-throttle-downshift-flare-587.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</guid>
										<title>1989 - 1996 Corvette: Service Bulletin: Information on Corvette ZF 6-Speed Manual Transmission Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1996-corvette-service-bulletin-information-on-corvette-zf-6-speed-manual-transmission-service-procedure-602.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</guid>
										<title>Regarding Product Campaign Bulletin 95-C-16 High Shift Effort into Reverse Gear on Manual Transmission - 1995 Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</guid>
										<title>1994 Corvette: Service Bulletin: Garage Shift Delay Engagement (New Garage Shift Package)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-garage-shift-delay-engagement-new-garage-shift-package-595.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</guid>
										<title>1996 Corvette: Transmission Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</guid>
										<title>1989 - 1991 Corvette: Service Bulletin: No/Delayed Reverse When Cold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-no-delayed-reverse-when-cold-603.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</guid>
										<title>1984 - 1987 Corvette: Technical Article: Rebuilding the Doug Nash 4+3 Overdrive Unit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-technical-article-rebuilding-the-doug-nash-4-3-overdrive-unit-610.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</guid>
										<title>1995 Corvette: Service Bulletin: 3 - 2 Downshift Flare (Reflash Control Module)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</link>
