<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-transmission-diagnostic-trouble-codes-586.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-harsh-1-2-upshift-597.html</guid>
										<title>1992 Corvette: Service Bulletin: Harsh 1-2 Upshift</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-harsh-1-2-upshift-597.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Evaluating Peened Spacer Plate (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</guid>
										<title>Regarding Product Campaign Bulletin 95-C-16 High Shift Effort into Reverse Gear on Manual Transmission - 1995 Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/regarding-product-campaign-bulletin-95-c-16-high-shift-effort-into-reverse-gear-on-manual-transmission-1995-corvettes-1406.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-transmission-maintenance-information-four-speed-manual-transmission-with-automatic-overdrive-1002.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Transmission Maintenance Information - Four-Speed Manual Transmission with Automatic Overdrive</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-transmission-maintenance-information-four-speed-manual-transmission-with-automatic-overdrive-1002.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</guid>
										<title>1995 Corvette: Service Bulletin: 3 - 2 Downshift Flare (Reflash Control Module)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-service-bulletin-3-2-downshift-flare-reflash-control-module-591.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Transmission Exchange Program 6 Speed M/T (ML9)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</link>
