<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Intermittent No-Start Condition Caused by Vehicle Anti-Theft System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-ecm-codes-579.html</guid>
										<title>1985 - 1991 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-ecm-codes-579.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-rattle-from-turn-signal-lever-1202.html</guid>
										<title>1984 - 1987 Corvette:  Service Bulletin:  Rattle From Turn Signal Lever</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-rattle-from-turn-signal-lever-1202.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</guid>
										<title>1984 - 1996 Corvette:  Wiring and Circuit Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-steering-wheel-removal-504.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Steering Wheel Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-steering-wheel-removal-504.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</guid>
										<title>1990 Corvette: Recall: Instrument Panel Wire Abrasion - Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</guid>
										<title>1990 Corvette: Service Bulletin: Tech 1 Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</guid>
										<title>1988 Corvette: Service Bulletin: 1988 Anniversary Model: Discolored Door Armrest</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</guid>
										<title>1992 Corvette: Recall: Optispark Distributor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</link>
