<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1990-corvette-service-bulletin-underhood-lamps-inoperative-or-staying-on-581.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Rear Hatch Defogger Circuit Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Intermittent No-Start Condition Caused by Vehicle Anti-Theft System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</guid>
										<title>1990 Corvette: Service Bulletin: Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</guid>
										<title>1990 Corvette: Service Bulletin: Tech 1 Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Low Coolant Warning Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Generator Noise (Moan) at Idle with Air Conditioning On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</link>
