<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Low Coolant Warning Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Revised Code 42 Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</guid>
										<title>1990 Corvette: Service Bulletin: Inflatable Restraint Indicator Lamp Stays On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-radio-may-lose-some-functions-inspect-radio-fuse-567.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Radio May Lose Some Functions, Inspect Radio Fuse</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-radio-may-lose-some-functions-inspect-radio-fuse-567.html</link>
