<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1991-corvette-service-bulletin-new-delco-loc-ii-setting-procedure-and-information-571.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</guid>
										<title>1992 - 1996 Corvette: Service Bulletin: Engine Miss/Poor Driveability Symptoms</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Starter Inoperative/Clicks/No Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Optispark  - Dissection &amp; Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</guid>
										<title>1979 - 1984 Corvette:  Service Bulletin:  Power Antenna Rod and Cable Service Package</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Intermittent No-Start Condition Caused by Vehicle Anti-Theft System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</guid>
										<title>1991 Corvette: Service Bulletin: Delayed Accessory Bus (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</link>
