<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</guid>
										<title>1990 Corvette ZR-1: Service Bulletin: Leaking Radiator Hose Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-zr-1-service-bulletin-leaking-radiator-hose-service-480.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: Engine Noise - Install Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-noise-install-bushing-486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</guid>
										<title>1984 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C22 Relocation of Cruise Control Servo Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-intermittent-no-start-no-crank-diagnostic-service-procedure-574.html</guid>
										<title>1988 - 1991 Corvette: Service Bulletin: Intermittent No-Start/No-Crank Diagnostic Service Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-intermittent-no-start-no-crank-diagnostic-service-procedure-574.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</guid>
										<title>1987 Corvette:  Service Bulletin:  Engine Harness Cut by Casting Flash on Transmission Housing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</guid>
										<title>1989 Corvette: Service Bulletin: Bose Amplifiers Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</link>
