<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Intermittent Radio Condition Remove/Replace Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</guid>
										<title>1990 Corvette: Recall: Instrument Panel Wire Abrasion - Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</guid>
										<title>1992 - 1996 Corvette: Tech Article: Quietly Powerful: How to Build a C4 LT1/4/5 Exhaust that Gains 28 hp and...is Quiet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-tech-article-quietly-powerful-how-to-build-a-c4-lt1-4-5-exhaust-that-gains-28-hp-and-is-quiet-512.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</guid>
										<title>1990 - 1991 Corvette: Service Information: Service Tips for Supplemental Inflatable Restraint (SIR)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Transmission Exchange Program 6 Speed M/T (ML9)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-transmission-exchange-program-6-speed-m-t-ml9-604.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Revised Code 42 Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-service-program-483.html</guid>
										<title>1990 - 1992 Corvette ZR-1: Service Bulletin: Engine Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1992-corvette-zr-1-service-bulletin-engine-service-program-483.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-technical-article-lt5-secondary-port-operation-vacuum-diagnosis-482.html</guid>
										<title>1990 - 1995 Corvette ZR-1: Technical Article: LT5 Secondary Port Operation &amp; Vacuum Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1995-corvette-zr-1-technical-article-lt5-secondary-port-operation-vacuum-diagnosis-482.html</link>
