<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</guid>
										<title>1984 - 1996 Corvette:  Wiring and Circuit Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</guid>
										<title>1984 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</guid>
										<title>1992 Corvette: Recall: Optispark Distributor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-optispark-distributor-554.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-high-output-ignition-coil-replacement-578.html</guid>
										<title>1985 Corvette: Service Bulletin: High Output Ignition Coil Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-high-output-ignition-coil-replacement-578.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Intermittent Radio Condition Remove/Replace Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</guid>
										<title>1990 Corvette: Service Bulletin: Service Manual Update Sec. 6D1 - Battery Spec. Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</guid>
										<title>1990 Corvette: Service Manual Update: SEC. 6D4 Spark Plug Coding Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</link>
