<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-tech-1-revised-odometer-recalibration-procedure-560.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</guid>
										<title>1987 Corvette:  Service Bulletin:  Engine Harness Cut by Casting Flash on Transmission Housing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</guid>
										<title>1991 Corvette: Service Bulletin: Information / Installation of Underhood / Courtesy Lamp</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</guid>
										<title>1984 - 1996 Corvette: Speedometer Gear Applications and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Power Antenna Will Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</guid>
										<title>1991 Corvette: Service Bulletin: Delayed Accessory Bus (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</guid>
										<title>1984 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</link>
