<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</guid>
										<title>1990 Corvette: Service Bulletin: SIR Revised Code 42 Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-sir-revised-code-42-chart-502.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</guid>
										<title>1994 - 1996 Corvette: Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-diagnostic-trouble-codes-551.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</guid>
										<title>1990 Corvette: Service Bulletin: Inflatable Restraint Indicator Lamp Stays On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</guid>
										<title>1990 - 1991 Corvette: Service Bulletin: Intermittent Radio Condition Remove/Replace Radio</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-bulletin-intermittent-radio-condition-remove-replace-radio-569.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</guid>
										<title>1984 - 1996 Corvette: Speedometer Gear Applications and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</guid>
										<title>1990 Corvette: Service Bulletin: Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</link>
