<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-ecm-codes-556.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Power Antenna May Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</guid>
										<title>1996 Corvette: Engine Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</guid>
										<title>1990 Corvette: Recall: Instrument Panel Wire Abrasion - Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Rear Hatch Defogger Circuit Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rear-hatch-defogger-circuit-revision-1076.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Starter Inoperative/Clicks/No Start</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-starter-inoperative-clicks-no-start-559.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</guid>
										<title>1990 Corvette: Service Bulletin: Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: S.I.R. System Diagnostic Energy Reserve Module Exchange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-s-i-r-system-diagnostic-energy-reserve-module-exchange-501.html</link>
