<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1996-corvette-service-bulletin-shortened-range-with-passive-keyless-entry-pke-transmitter-552.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</guid>
										<title>1984 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</guid>
										<title>1984 Corvette: Recall: Positive Battery Cable Routing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-positive-battery-cable-routing-881.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</guid>
										<title>1984 - 1996 Corvette: Speedometer Gear Applications and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</guid>
										<title>1990 Corvette: Service Bulletin: Radio May Lose Some Functions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-radio-may-lose-some-functions-159.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</guid>
										<title>1991 Corvette: Service Bulletin: Information / Installation of Underhood / Courtesy Lamp</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-information-installation-of-underhood-courtesy-lamp-557.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</guid>
										<title>1990 Corvette: Service Bulletin: Inflatable Restraint Indicator Lamp Stays On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</guid>
										<title>1996 Corvette: Engine Diagnostic Trouble Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1996-corvette-engine-diagnostic-trouble-codes-549.html</link>
