<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-windshield-wipers-chatter-and-or-wipe-unevenly-1089.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Windshield Wipers Chatter and/or Wipe Unevenly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-windshield-wipers-chatter-and-or-wipe-unevenly-1089.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-convertible-mounting-bracket-rattle-at-rear-of-hardtop-656.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Convertible: Mounting Bracket Rattle at Rear of Hardtop</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-convertible-mounting-bracket-rattle-at-rear-of-hardtop-656.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-convertible-top-number-5-bow-weatherstrip-loose-660.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Convertible Top Number 5 Bow Weatherstrip Loose</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-convertible-top-number-5-bow-weatherstrip-loose-660.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-window-regulator-repair-replacement-procedure-670.html</guid>
										<title>1984 - 1987 Corvette: Service Bulletin: Window Regulator Repair Replacement Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-window-regulator-repair-replacement-procedure-670.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Cracks/Damage to Cowl Surface</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</guid>
										<title>1984 - 1996 Corvette:  Service Bulletin:  Cleaning and Lubricating Power Antenna Mast Sections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-cleaning-and-lubricating-power-antenna-mast-sections-1078.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</guid>
										<title>1984 - 1996 Corvette: Water Leakage: Preventing Water Leaks Into the Interior Near Side Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Roof Panel Attaching Point Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-paint-code-release-update-information-665.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Paint Code Release Update Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-paint-code-release-update-information-665.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-information-on-door-lock-system-components-and-replacement-components-653.html</guid>
										<title>1990 Corvette: Service Bulletin: Information on Door Lock System Components and Replacement Components</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-information-on-door-lock-system-components-and-replacement-components-653.html</link>
