<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-oil-dipstick-hitting-crankshaft-on-5-7l-l83-engine-546.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</guid>
										<title>1990 - 1996 Corvette: Oil Life Monitor: Reset the Engine Oil Life Monitor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c25-rear-axle-differential-cross-shaft-1118.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C25 Rear Axle Differential Cross Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c25-rear-axle-differential-cross-shaft-1118.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</guid>
										<title>1988 - 1989 Corvette: Recall: Evaporative Emission Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Revised Procedure - Install or Connect Intake Manifold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-lt1-reverse-flow-cooling-system-526.html</guid>
										<title>1992 - 1996 Corvette: Technical Article:  LT1 Reverse Flow Cooling System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-lt1-reverse-flow-cooling-system-526.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Rocker Arm Cover Removal Procedures - Right Side</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</guid>
										<title>1985 Corvette: Recall: Mass Air Flow Sensor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</link>
