<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-multec-fuel-injectors-cleaning-information-538.html</guid>
										<title>1986 - 1991 Corvette: Service Bulletin: Multec Fuel Injectors / Cleaning Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-multec-fuel-injectors-cleaning-information-538.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</guid>
										<title>1988 - 1989 Corvette: Recall: Evaporative Emission Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Fuel Pump Driveability Issue - Diagnostic Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</guid>
										<title>1994 - 1995 Corvette: Service Bulletin: Information on Air Intake Duct Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</guid>
										<title>1986 - 1990 Corvette: Service Bulletin: New Design Cylinder Heads Production Change Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</guid>
										<title>1995 Corvette: Ignition: No-Start Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Revised Procedure - Install or Connect Intake Manifold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</guid>
										<title>1992 Corvette: Recall: Oil Leak at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</link>
