<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l98-engine-throttle-body-diagram-542.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</guid>
										<title>1995 Corvette: Ignition: No-Start Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-engine-removal-procedures-545.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Engine Removal Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-engine-removal-procedures-545.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</guid>
										<title>1992 Corvette: Recall: Oil Leak at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Power Steering Fluid Cooler</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-rocker-arm-cover-gaskets-185.html</guid>
										<title>1985 Corvette: Service Bulletin: Rocker Arm Cover Gaskets</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-rocker-arm-cover-gaskets-185.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</guid>
										<title>1985 Corvette: Recall: Mass Air Flow Sensor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Optispark  - Dissection &amp; Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
