<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Rebuilding the LT1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-parasitic-driveline-loss-on-a-dynamometer-487.html</guid>
										<title>1984 - 1996 Corvette: Parasitic Driveline Loss on a Dynamometer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-parasitic-driveline-loss-on-a-dynamometer-487.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l98-engine-throttle-body-diagram-542.html</guid>
										<title>1985 - 1991 Corvette: L98 Engine Throttle Body Diagram</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l98-engine-throttle-body-diagram-542.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-oil-dipstick-hitting-crankshaft-on-5-7l-l83-engine-546.html</guid>
										<title>1984 Corvette: Service Bulletin: Oil Dipstick Hitting Crankshaft on 5.7L L83 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-oil-dipstick-hitting-crankshaft-on-5-7l-l83-engine-546.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</guid>
										<title>1990 - 1996 Corvette: Oil Life Monitor: Reset the Engine Oil Life Monitor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</guid>
										<title>1992 Corvette: Recall: Oil Leak at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c25-rear-axle-differential-cross-shaft-1118.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C25 Rear Axle Differential Cross Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c25-rear-axle-differential-cross-shaft-1118.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</guid>
										<title>1984 Corvette:  Recall Notice:  Product Safety Campaign 84C01 A.I.R Pump Pulley May Loosen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Rocker Arm Cover Removal Procedures - Right Side</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</link>
