<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Optispark  - Dissection &amp; Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Revised Procedure - Install or Connect Intake Manifold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-campaign-power-steering-pump-pulley-failure-182.html</guid>
										<title>1984 Corvette: Campaign: Power Steering Pump Pulley Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-campaign-power-steering-pump-pulley-failure-182.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</guid>
										<title>1985 Corvette: Recall: Mass Air Flow Sensor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-parasitic-driveline-loss-on-a-dynamometer-487.html</guid>
										<title>1984 - 1996 Corvette: Parasitic Driveline Loss on a Dynamometer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-parasitic-driveline-loss-on-a-dynamometer-487.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-service-engine-soon-light-code-36-pfi-engines-vin-codes-f-and-8-540.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Service Engine Soon Light - Code 36 PFI Engines (VIN Codes F and 8)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-service-engine-soon-light-code-36-pfi-engines-vin-codes-f-and-8-540.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-fuel-tank-pressure-control-valve-1166.html</guid>
										<title>1986 Corvette:  Recall Notice:  Fuel Tank Pressure Control Valve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-fuel-tank-pressure-control-valve-1166.html</link>
