<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-multec-fuel-injectors-cleaning-information-538.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</guid>
										<title>1995 Corvette: Recall: Distributor Vacuum Vent Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Noisy/Fraying Accessory Drive Belt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-minimum-idle-speed-revision-184.html</guid>
										<title>1985 Corvette:  Service Bulletin: Minimum Idle Speed Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-minimum-idle-speed-revision-184.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</guid>
										<title>1994 - 1995 Corvette: Service Bulletin: Information on Air Intake Duct Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-oil-dipstick-hitting-crankshaft-on-5-7l-l83-engine-546.html</guid>
										<title>1984 Corvette: Service Bulletin: Oil Dipstick Hitting Crankshaft on 5.7L L83 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-oil-dipstick-hitting-crankshaft-on-5-7l-l83-engine-546.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: Tail Pipe Smoke on Startup</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-camshaft-lobe-lift-specifications-547.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Camshaft Lobe Lift Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-camshaft-lobe-lift-specifications-547.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</guid>
										<title>1990 - 1996 Corvette: Oil Life Monitor: Reset the Engine Oil Life Monitor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Fuel Pump Driveability Issue - Diagnostic Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</link>
