<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-camshaft-lobe-lift-specifications-547.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Camshaft Lobe Lift Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-camshaft-lobe-lift-specifications-547.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</guid>
										<title>1984 - 1996 Corvette: Speedometer Gear Applications and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</guid>
										<title>1988 - 1989 Corvette: Recall: Evaporative Emission Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-coolant-usage-recommendation-service-information-533.html</guid>
										<title>1988 - 1991 Corvette: Service Bulletin: Coolant Usage Recommendation Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-coolant-usage-recommendation-service-information-533.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Power Antenna May Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-power-antenna-may-not-retract-573.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</guid>
										<title>1989 Corvette: Service Bulletin: Bose Amplifiers Service Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-corvette-service-bulletin-bose-amplifiers-service-program-570.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Rocker Arm Cover Removal Procedures - Right Side</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</guid>
										<title>1984 - 1989 Corvette: Digital Dash Cluster Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Revised Procedure - Install or Connect Intake Manifold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</link>
