<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-coolant-usage-recommendation-service-information-533.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Rocker Arm Cover Removal Procedures - Right Side</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-rocker-arm-cover-removal-procedures-right-side-544.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</guid>
										<title>1984 - 1989 Corvette: Service Bulletin: Revised Procedure - Install or Connect Intake Manifold</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-service-bulletin-revised-procedure-install-or-connect-intake-manifold-548.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</guid>
										<title>1995 Corvette: Ignition: No-Start Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-excessive-engine-oil-consumption-rough-idle-519.html</guid>
										<title>1994 Corvette: Service Bulletin: Excessive Engine Oil Consumption/Rough Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-excessive-engine-oil-consumption-rough-idle-519.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-axle-lube-change-935.html</guid>
										<title>1984 Corvette:  Service News:  Axle Lube Change</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</guid>
										<title>1994 - 1995 Corvette: Service Bulletin: Information on Air Intake Duct Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-oil-leaks-from-rear-of-engine-522.html</guid>
										<title>1992 Corvette: Service Bulletin: Oil Leaks From Rear of Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-oil-leaks-from-rear-of-engine-522.html</link>
