<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-minimum-idle-speed-revision-184.html</guid>
										<title>1985 Corvette:  Service Bulletin: Minimum Idle Speed Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-minimum-idle-speed-revision-184.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Noisy/Fraying Accessory Drive Belt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Rebuilding the LT1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</guid>
										<title>1994 - 1995 Corvette: Service Bulletin: Information on Air Intake Duct Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</guid>
										<title>1986 - 1990 Corvette: Service Bulletin: New Design Cylinder Heads Production Change Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</link>
