<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</guid>
										<title>1990 - 1991 Corvette: Service Information: Service Tips for Supplemental Inflatable Restraint (SIR)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Intermittent No-Start Condition Caused by Vehicle Anti-Theft System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Electric Outside Rear View Mirrors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-electric-outside-rear-view-mirrors-582.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Low Coolant Warning Light</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1996-corvette-service-bulletin-shortened-range-with-passive-keyless-entry-pke-transmitter-552.html</guid>
										<title>1993 - 1996 Corvette: Service Bulletin: Shortened Range With Passive Keyless Entry (PKE) Transmitter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1996-corvette-service-bulletin-shortened-range-with-passive-keyless-entry-pke-transmitter-552.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</guid>
										<title>1991 Corvette: Service Bulletin: Delayed Accessory Bus (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html</link>
