<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1964-corvette-service-news-radiator-lower-hose-replacement-53.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</guid>
										<title>1967 - 1968 Corvette:  Engineering Service Note:  Idle Cooling and Dieseling on Corvette with 427 CU IN Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-1968-corvette-engineering-service-note-idle-cooling-and-dieseling-on-corvette-with-427-cu-in-engines-1226.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</guid>
										<title>1963 Corvette:  Field Service Engineering:  Intake Manifold Baffle Rivet Hole Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-field-service-engineering-intake-manifold-baffle-rivet-hole-leak-1057.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</guid>
										<title>1965 Corvette: Service News:  Engine Removal Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-engine-removal-revised-157.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 396-425 H.P. RPO L-78 Incorrect Build</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-396-425-h-p-rpo-l-78-incorrect-build-28.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</guid>
										<title>1966 Corvette: Service Bulletin: Water Pump Pulley Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-water-pump-pulley-failures-84.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</guid>
										<title>1963 Corvette: Service News: Radiator Service Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-news-radiator-service-updates-734.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</guid>
										<title>1965 Corvette: Service Bulletin: Valve Spring Cap Failure - 425 H.P., 396 ci. Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-valve-spring-cap-failure-425-h-p-396-ci-engines-731.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</guid>
										<title>1965 - 1967 Corvette:  Tonawanda Engine Service Notes:  Valve Springs, Rocker Arms, Camshafts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1967-corvette-tonawanda-engine-service-notes-valve-springs-rocker-arms-camshafts-1224.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Increased Capacity Fuel Pump</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-increased-capacity-fuel-pump-1234.html</link>
