<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-axle-lube-change-935.html</guid>
										<title>1984 Corvette:  Service News:  Axle Lube Change</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c25-rear-axle-differential-cross-shaft-1118.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C25 Rear Axle Differential Cross Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c25-rear-axle-differential-cross-shaft-1118.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</guid>
										<title>1988 - 1989 Corvette: Recall: Evaporative Emission Hoses</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-recall-evaporative-emission-hoses-535.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Noisy/Fraying Accessory Drive Belt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin: Intermittent No Start / Cranks Replace Mass Air Flow Relays</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</guid>
										<title>1987 - 1991 Corvette: Service Bulletin: Tail Pipe Smoke on Startup</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-coolant-usage-recommendation-service-information-533.html</guid>
										<title>1988 - 1991 Corvette: Service Bulletin: Coolant Usage Recommendation Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-coolant-usage-recommendation-service-information-533.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</guid>
										<title>1990 - 1996 Corvette: Oil Life Monitor: Reset the Engine Oil Life Monitor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</link>
