<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-multec-fuel-injectors-cleaning-information-538.html</guid>
										<title>1986 - 1991 Corvette: Service Bulletin: Multec Fuel Injectors / Cleaning Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-multec-fuel-injectors-cleaning-information-538.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-excessive-engine-oil-consumption-rough-idle-519.html</guid>
										<title>1994 Corvette: Service Bulletin: Excessive Engine Oil Consumption/Rough Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-excessive-engine-oil-consumption-rough-idle-519.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</guid>
										<title>1995 Corvette: Ignition: No-Start Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-ignition-no-start-condition-517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</guid>
										<title>1986 Corvette: Service Bulletin: Spark Plug Service on Engines with Aluminum Heads</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-service-bulletin-spark-plug-service-on-engines-with-aluminum-heads-537.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</guid>
										<title>1992 - 1996 Corvette:  Service Bulletin:  Oil Leaks Between Intake Manifold and Engine Block</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-minimum-idle-speed-revision-184.html</guid>
										<title>1985 Corvette:  Service Bulletin: Minimum Idle Speed Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-minimum-idle-speed-revision-184.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Power Steering Fluid Cooler</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</guid>
										<title>1992 - 1996 Corvette: Technical Article: Rebuilding the LT1 Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-rebuilding-the-lt1-engine-524.html</link>
