<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-technical-article-optispark-dissection-replacement-525.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Generator Noise (Moan) at Idle with Air Conditioning On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-generator-noise-moan-at-idle-with-air-conditioning-on-1244.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-campaign-power-steering-pump-pulley-failure-182.html</guid>
										<title>1984 Corvette: Campaign: Power Steering Pump Pulley Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-campaign-power-steering-pump-pulley-failure-182.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</guid>
										<title>1990 Corvette: Service Bulletin: Revised Odometer Recalibration Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-revised-odometer-recalibration-procedure-563.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</guid>
										<title>1992 - 1996 Corvette: Service Bulletin: Engine Miss/Poor Driveability Symptoms</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</guid>
										<title>1984 Corvette:  Recall Notice:  Product Safety Campaign 84C01 A.I.R Pump Pulley May Loosen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</guid>
										<title>1990 Corvette: Service Bulletin: Service Manual Update Sec. 6D1 - Battery Spec. Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-service-manual-update-sec-6d1-battery-spec-chart-562.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-excessive-engine-oil-consumption-rough-idle-519.html</guid>
										<title>1994 Corvette: Service Bulletin: Excessive Engine Oil Consumption/Rough Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-excessive-engine-oil-consumption-rough-idle-519.html</link>
